Resource Usage monitoring with Zabbix for Dedicated Nodes with Client VMs
Check VM Access
Login to customer portal with the provided login details:
Login to Zabbix Portal: https://zabbix.diadem-tech.com/zabbix/
Click on Hosts on the Zabbix Portal to check the VMs that are monitored
Check Data that are monitoring
Click on Latest Data
Check Data on based on a time period
Click on Graphs
Set the time period to be monitored
Change the User Password
Click on Profile and change the password
    • Server Resource Utilisation Monitoring with Plesk
      Plesk Server Monitoring helps to keep your Plesk running smoothly by tracking the server resource usage and notifying you when one or more resource usage reaches a predefined threshold. Note : For more information look for the reference url given ...
    • Generate Paid SSL Certificate through Client Portal and Plesk
      Generate Paid SSL Certificate through Client Portal and Plesk To generate a certificate from Plesk we can click on generate a new certificate as per the steps below. If CSR is already generated, then go to Step 3. Step 1: For Generating the SSL ...
    • Diadem VM Cloud Management Console Overview
      Diadem VM Cloud Management Console Login To Cloud Console Portal Managing the VPS Killing a process Checking System alerts Checking the Graphs Check the running services and manage them Change account password Technical Support Login To Cloud Console ...
    • Manage Your Hosting Account from Client Portal
      Managing Your Hosting Account from Client Portal Managing your Plesk Hosting Account through your Customer Portal Add a domain to your hosting service Create a Database Add Domain Aliases Manage DNS settings Email Accounts Email Forwarding FTP Access ...
