How to monitor bandwidth usages for a PRTG sensors
1. Log in to the admin panel using given URL and User-id/Password given to you: prtg.diadem-tech.com
2. Then click on Devices button.
3. Next go to the sensors and click on it.
4. Now you can monitor bandwidth usages from here.
Related Articles
Plesk Server Health Monitor
Plesk Server Health Monitor Overview Health Monitor helps you keep your Plesk installation running smoothly by keeping track of the system resources’ usage on the server and notifying you when one or more resources’ usage reaches a pre-defined ...
How to Block IP's which consume additional bandwidth in cPanel
How to Block IP's which consume additional bandwidth in cPanel How to Check Website Statistics Bandwidth usage in cPanel How to Block IP in cPanel How to Check Website Statistics Bandwidth usage in cPanel Step 1: Log in to cPanel. Step 2: In the ...
How to install Server Health Monitor, watchdog in Plesk
Installing Health Monitor and Watchdog Health monitor in monitoring and keeping track of the server resources and notifying the admin if the resources crosses the threshold limit. Install Health Monitor Step 1: Installing Health Monitor To Install ...
How to monitor and clean malware using ImunifyAV extension
What is ImunifyAV? ImunifyAV is an antivirus and website security monitoring tool, with one-click auto malware cleanup facility. It also helps in monitoring domain reputation and blacklist checking. Setup details from Immunify is located at: ...
How to use MSSQL Activity Monitor to find the most expensive query
There are certain ways to identify and troubleshoot long running queries.This prevents potential performance issues. SQL Activity Monitor is the easiest and rich UI tool available in SQL Server Management Studio.It provides information about ...
